Bronco part needed
Donodie
I think the right name is an intermideate housing. I call it transmission tail piece. Well I cracked mine and have been told the drivetrain i have is a rare one, I guess it's because it's so WIMPY. It's aluminum about 8.5" long and serves no purpose but for linkage connections. Any info? because I cant find one!!
Thanks donodie
D
Donodie
Need more info . What kind of tranny C4,C6,AOD,E4OD . What year ? I do have one for an E4OD.  :D /emoticons/[email protected] 2x" width="20" height="20" />
21070[/snapback]
1983 300ci straight 6. not sure about tranny. manual 4speed with OD. I've been told there was only 238 of these engine and drivetrains made that year but you ya gonna believe?
D
Donodie
21073[/snapback]
Found somemore info. Warner T-18 four speed Tranny with What the book calls "New process gear 208 transfer case"
You stated the trany is a 4-speed manual with overdrive/OD, but the T-18 does not have OD. IF you have OD, it can either be a SROD or TOD tranny. Whichever of those models you have, they will have an ID tag/label on the driver's side of the tranny housing. If you don't see any label, look on the passenger-side. IF it has a square, bolt-on cover plate for the PTO output there will be a metal tag with numbers on it. Ford put all sorts of tranny and engine combo's in the 83-86 Bronco, some with the NP208 or B-W transfer case, and some with a Ford 9" or Ford 8.8" rear axle. IF you can determine what all of the drivetrain parts are in your 83, I might find the extension housing for you. I'm currently looking around for stuff for my 86 Bronco with a NP435 manual tranny and NP208, JSM84
Wihill
