jeremyposey
- Joined
- Jul 5, 2011
- Messages
- 1
- Reaction score
- 0
Ok, a little about myself, I used to be a mechanic in the us army, I have short trem memory loss and slight brain damage now.
So I need some help.
I have a 1991 ford bronco xlt with a 5.8l.
this vehicle sat for 6 years at my dads house, untill 3 weeks ago.
I have changed my fuel pump, fuel filter, blew out fuel lines. changed both green and brown relays. changed coil, Grey TFI on side of dizzy, changed pip inside of distributor.
1. Past issues. 2 weeks ago I was driving and the engine lost power, started pinging and backfiring. then it would die. after about
40 mins it would fire right up. and then 10 20 mins later would do the same thing SO I CHANGED MY TFI. the problem was still the same,
would run great cold, and then would die when warm. but now it would fire right back up, instead of waiting 40 mins.
SO then I CHANGED MY GREEN RELAY AND BROWN RELAY. CHANGED MY COIL AND PIP INSIDE OF DIZZY.
NOW it starts rights up, will run but is constantly dying. will pull off the road wait 5 mins. and then I am good for another 10-20
minutes of driving before it dies agian.
WHAT AM I MISSING? I have spent all 4th of july weekend cleaning grounds and checking connections. all seems ok.
Here are some questions I have.
1.WHAT IS THE GREY RELAY? UNDER THE HOOD NEXT TO THE GREEN AND BROWN ONE. DOESNT SEEM TO MAKE A DIFFERENCE IF I REMOVE IT OR NOT.
2. COULD A FAULTY TPS SENSOR CAUSE THESE PROBLEMS. I HAVE DRIVEN WITH IT DISCONNECTED. STILL DIED. JUST SHIFTED HARSH.
3. COULD THE COOLANT TEMP SENSOR CAUSE THIS PROBLEM?
4. I am suspect of my starter relay, silinoid on the passenger firewall next to the vaccum canisters.
Please Please point me in the right direction.
Because of my short term memory loss I have a really hard time working out of a repair book now. I cant remember the steps or where
I am at in the diagnosis process.
Thank you for your help.
