Bronco II how far can you go
manchesterutd81
[-o< ok i am noob but i have search your whole site and a few others that yall said to search, just like yall say to every other noob, here is my question i just bought a 1989 bronco II and the guy put a ton of spacers in the front coils, 2 rubber ones and 2 expandable metal ones the ones with the the 2 bolts with nuts that expand and get this 2 of the ***** in type alum ones and its the same on the other side, he also put superlift shocks on the front i guess the ones that are longer or something, in the rear he has those boxes like 2 of them i guess its like 5 inches or maybe 4 all i know is it has 35s on it and its high, like from the ground to the bottom of the fender or body its 24 inches off the ground now thats not the frame i went from the bottom of the body ok, right so i just purchased a 3inch body lift and all the new mounts to up date cause the mounts are all dry rotted.... with the 3ich body lift i should then be 27inch off the ground what will this get me in the way of tires oh and i am about to hack the heck out of the fenderwells cause its a fun vehical and looks don't matter all i want is big tires and removable doors, oh here is a little hoot its a 2wd lol so bash away and its the v6 with the 5speed, ok so what does everyone think and how do i cut the fenders cause if i have to i will hack them pretty bad if someone doesnt tell me how to do it right also if i cut them all the way off what kind of tire can i get on there with like spacers come on guys if you ever wanted to try something and see how it came out heres your chance, tell me what to do and ill try it, seeing that i have 3 of them laying around and i want to get creative
thanks
josh [-o<
If you're going to put it on the street.... do it right..! Don't risk your life & others..! [-X
All the parts houses have lift kits to fit every budget.
Get a makita & a cut-off wheel. (& a face shield) ....you can make a pretty nice cut if you're careful. B)
M
manchesterutd81
awesome with this 3inch body lift i believe i am going to be able to fit 40s on this bad boy
Ralphdb
Lakeland Florida
You better get some training wheels because on the first curve in the road it is going to fall over... this truck like any other Off roader will be dangerous. can you say Roll Over.. I am talking if you are on a Incline and lean over too far. it is gone.. Use common Sense.. You don't even mention what size engine you have.. you need 4:88's or more to turn a 40 inch tire.. you could never spin them to clear the Mud from the grooves.
digs
