Bronce Ii Getting No Fuel
bobbyk
have 87 bronco II cant get no fuel to motor have change i think every ignition part and computer related part on vehicle but cant seem to get any fuel if i spray fuel into in take it will run till i quit spraying its a 2.9 mpfi engine please help :( /emoticons/[email protected] 2x" width="20" height="20" />
STLKIKN
Calgary Alberta
WHen you cycle the key from the off position to the run position, can you hear the fuel pump(s) running for about three seconds?/
Have you checked to see if the inertia switch (fuel pump cut-off) has been tripped?
Jake2970
also if you replaced the fuel pumps check the front pump on the frame happend to a freind of mine no flow arrows on new pump so he installed it so it matched the one he pulled out but it was backwards
Jake
G
Guest
Guest
Don't forget to check the relays if you haven't already, a friend of mine spent over a hundred bucks on a fuel pump and it turned out to be the relay(a lot cheaper!)
monty06
Miami,Florida
B) >:)
i would start by changing the simple things and checking as you go along
fuel filter and fuel pump relay. check your fuel rail is it's not clogged
check your fpr is it's not clogged or leaking check fuel lines also
inertia switch rarely goes out but does happen
i had the same problem last month
i changed the complete fuel system both pumps and sending unit,fuel filter,fpr,fuel rail and injectors inertia switch, etc..
turned out to be the tps sensor in my case while i was doing fuel i out in a high capacity fuel tank 36 gallons and custom skid plate
pull codes if you can
Billz4x4z
Carnesville,GA
Fuel filter....fuel pressure regulator,fuel pump relays,inertia switch fuel pump,ground for fuel pump at the tank.Do you hear the fuel pump running at all??
commando1087
[under the driver side door in the frame there is a box and if u look in that box there are wires running into make sure all wires are not loose or try and push them all in if they go in ur truck will start gaurunteed
MasterPain
Got about the same problem both pumps are clicking but won,t stay running.
Could someone help me out?
yusuebronko2_86
San Antonio TX
i've had the same problem on my '86 b2, and it turned out to be that the ecm ground (located behind the passenger kick panel in the cab) was terrible, as well as the one in the motor bay, so the computer wasn't even working, thus the injectors wouldn't fire. you should try pulling up a wiring diagram off the internet or go wire-hunting with a voltometer multi-tool and find the ground wires to the ecm. :)>-
digs
