i got a new caliper for my front drivers side rotor and got all that settled. and then the other day decided to bleed the breaks and had everythin done rite i know i did it rite. well then i pulled the truck out today and i had no breaks at ALL! i found out that my passenger side calipers main break line didnt have both copper fittings on the bolt so fixed it. i bled them again. and then i started it again and did have a little better breaks but still very pathetic! every time im done bleedin the pedal well ya know feels stiff like a break pedal should THEN i start the truck and it seems like i have to push the pedal all the way to the floor to get little to hardly any catch on the pads. ive bled them twice and they dont get any better. ALSO my rear drum breaks i have tried to bleed but absolutely NOOO fluid comes out when i do. of EITHER END LEFT OR RIGHT DRUM! i know my left drum brake clinder is blew and needs to be replaced but still i would think SOME fluid would come out... All in All i want and of course NEED my brakes back. any and !ALL! answers and comments would be appreciated! my trucks almost done and really need this to be done with!
Also... i took off the booster from the firewall durin the rebuild and was wonderin if i did that if i had to bleed the master cylinder directly or if i could just put it back on and bleed it from the lines. cause i didnt bleed it directly. thanx yall God bless
