Dave
Ok well after I got my axle seal fixed I was going to try out the 4 wheel drive. Well when I started it up and pushed the brake it went to the floor adn the brake light came on. So we bleed the brakes and still nothing. The pedal still isn't any better. Some times the light comes on and some times it doens't. It has got a new master cylinder on it,(which doesn't mean anything), none of the wheel cylinders are leaking. The pedal feels fine except it doesn't stop before the floor. You can go down the drive way and jab the brakes and it will barely skid a tire. I have new stainless brake lines coming with my lift kit so I know that will not be an issue. What do you think it could be? Oh yeah when you have the pedal pressed and mash the gas the brake pdal wants to push back up. Thanks for your help guys.
