Brake Lights on With Ignition and Hazard Lights Only Work when no igni
wvhillbilly96
He guys. Usually can find what I need from the Archives. But not this time. My problem is this: I have a 1996 Bronco, 351 Engine. Yesterday my cruise control wouldn't work. Noticed that my brake lights come on when I turn on the vehicle. So I hit ignition and brake lights come on and stay on. Flashers won't work. But when I turn off ignition the flashers work. Replaced flasher circuit breaker Check brake light switch mounted on brake pedal and its good. My cruise control was working fine yesterday. No it won't work. It is as if the brakes are engaged and the cruise wont come on-as if you tapped the break to get them to disengage. I have checked all the fuses to no avail. Help me please.
yi WV!
D
Was the Cruise Ctrl Recall work done?
Recall Update; Field Service Action 05S28 Speed Control System Modification Supplement #7 for 94-96 Bronco, 94-02 F-150/250 (Under 8500 GVW), 97- 02 Expedition, 98-02 Navigator, 02 Blackwood
Troubleshooting Chart, Electronic Servo System in 93-96
Source: by Ford via Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/177061
see the wiring diagram there as well as the Recall Update
check that brake switch
Next is da Multifunction Switch (MFS), Hazard, Turn, High & Low Headlight Dimmer, Flash-to-Pass & Brake Light Testing & Wiring Diagram in 92-96; If MFS is bad, get one from any 92-96 Bronco or Ford Truck bec as Steve wrote; They are electrically & functionally identical. Only the shape & finish of the stalk is different.
Source: by Steve83 at http://www.supermotors.net/registry/media/225114_1
The brake light ckt flows thru the MFS; test that first if other tests above show no problem and recall work was done.
W
wvhillbilly96
yi WV!
D
Thank you for your quick response! Just the kind of answer I was looking for. I find electrical problems pretty challenging. I thought I was going crazy doing all this troubleshooting. I bet its the MFS. Great idea about the recall. I'll call Ford in the morning. By the way, I love this forum. This forum has saved me hundreds, if not thousands of dollars keeping my Bronco running like a top. Great stuff guys!
YW WV!
You could also check the recall status on-line @ Ford http://www.flmowner.com/servlet/ContentServer?pagename=Owner/Page/RecallsPage
Have VIN ready
Register there and if you get service work or buy parts, Ford will credit you w/$ to apply to next visit or part.
"Enrolled Members receive:
$10 enrollment bonus toward a future parts or service purchase
5% credit on all parts and service purchases that can be applied toward future service visits
Rewards on every vehicle in your household, no matter what make or model
Special complimentary oil change offers*
* Taxes extra. Disposal fee not included in some locations. See Service Advisor for details.
honesthat
