I have a 1976 Ford Bronco with a brand new Centech wiring harness. I have a few problems. The brake lights stay on unless I unplug the brake light switch even if the key/lights are turned off. My column is a hack and I am getting ready to change it and do not currently have any hazard lights. Should I go with in dash or try to get the new column (out of a 1979 full size bronco) to work. Finally, The turn signals work when the lights are on but the marker light that doubles as a turn signal does not work. It works as a marker light until I turn the lights on. Finally, the brake light switch wire does not work with an aftermarket proportioning valve from west coast broncos. It has two terminals in an oval connector whereas the aftermarket proportioning valve only has a one pin in a round connector. Thanks in advance. /emoticons/[email protected] 2x" width="20" height="20" />
