Body Lift
Gran Sabana
is any aftermarket rear bumper bracket when you use a 3 in body lift kit . The rear bumper looks awfull in that way.
Mario
93 Bronco
Venzuela
Bulldozer
Mine has that two, an easier way than a bumper is buyig a rollpan.
highboy73
FORDing thru life
morocco,indiana
make one,get some plate and drill it out to fit the old holes line up your bumper and mark the new holes and then drill them out put it all back together and then you got it.
if you are worried about strength get a hitch mount,reciever,whatever you want to call it.
you shouldn't pull with your bumper anyway,in my opionin,by a hitch they are cheap and made for it.
Bulldozer
I tired un doing the brackets on my back bumper, i was using an air gun and they wouldnt come out, some are stuborn so now theres a 5inch gap on the back.
MattWilliams31
I just took the brackets off of my bumper and flipped them around on my 88 when i put the 3 inch body lift on. i was able to line up one hole in each bracket and tighten them up enough to hold the bumper on well enough. I took it to my friends house later and had him spot weld the brackets to the frame. looks perfect. cant even tell. now if only there was a way to do the front
Wihill
