body lift?????????
txmudder
i was thinking of putting a body lift on by performance accessories but was wandering how hard it would be and what would need?
From looking at the kits, they seem to be complete. If so, all you will need is tools. Do one side at a time so the body doesn't shift, just loosen the bolts on the side that is not being done. However, be prepared for some of the body bolts to be frozen solid and most likely will have to be cut. I changed my body mounts a while ago and had to cut 4 of them, not an easy job since you are cutting #8 bolts. I had to use a Sawzall with a carbide blade. Here is a link to the subject of Body Mounts, I wrote up my experience there http://broncozone.com/topic/22416-body-mount-bushings/page__p__116936?do=findComment&comment=116936
T
txmudder
do you know what i will have to do any extentions on anything if so what and how hard
Bronc76
Probably extend the linkage if its an automatic and modify the fan shroud.
guilhermeknob
