blower motor resistor
grande_guerre
grande mondiale
originally-Alaska, temporarily-Arizona
my blower motor hasnt been working for awhile, and looked at the resistor. is it supposed to be missing the pin in the upper corner??? if not, i'm pretty sure the problems in my switch, i think the wire is all corroded. maybe....
Here is some additional information to help you troubleshoot the problem. When you say, "out from the motor", at what point are you measuring the voltage? These diagrams are from the 1983 EVTM but that circuit hasn't changed, so it should also be the same on your truck.
david@holycitytransportat
