best lift
Santafebronco
I was wondering if any one out there has any experience with the superflex 5.5 inch lift that bronco graveyard sales. Or if there is a better lift for my money and what lifts all you other bronco fans love? I have a 96 351w auto trans. I would like something where i get more articulation and flex than something that is done just to stuff bigger tires under the big bad bronc
In my experience, the Superlift kits are generally a bit "softer" and "more flexy" than the Skyjacker Class II kits. But alot will depend on whether you go with lift blocks, an AAL or new liftged spring packs for the rear. The Skyjacker springs are definitely stiffer than stock, and I usually take out the bottom overload spring to soften the ride. Personal preference, I actually prefer the ride of the SkyJ kit by keeping me from getting tossed around in the cab. In other words, the Superlift kit is too soft for my taste in wheelin', JSM84
Miss Kitten
alberta canada
to get good flex out of the front end of the truck make sure whatever kit you go with has the extended radius arms.
you can look at doing a shackle flip in the rear too instead of add a leafs or blocks
rcarm74
