DNBELOWBRONCO
Looks good. When I went from 32's to 33's I used a normal $20 Harbor Freight electric grinder, wife works there, with a 4 1/2" cut-off wheel. It was easy. Just follow the curve of the fender opening with a marker. That way you can cut in a curved pattern and replace the cut-off wheel with a grinder wheel to smooth the sharp edges so no-one gets cut. You will have to get rid of the lower plastic air deflector, and for reference if you have the wide plastic bumper face moldings, your curve should stop right before the edge of the plastic! Since you're only cutting a few inches off, 99% of the people won't be able to tell you even cut it.......Oh, and I used a Rough Country 2.5" kit with rear replacement leafs and just used the stock pinion wedge to keep the pinion angle correct. It will be the same with your blocks. You "Need" to use the stock wedge to make it right. Other than that, you don't need to mess with the drive shaft or anything other than the alignment bushings. With that size lift your alignment guy should easily compensate for the camber and toe adjustments. I was close to a 3" setup so I used radius arm drop brackets, at the advise of my alignment guy, so I wouldn't need 3+ deg bushings. I think the brackets were $50-$60 a pair, but there's always used sets, so if you run into any issues that is always an option to get the back of the arms down and level... >
-Kevin-
