AutoZone has a tool rental program where you pay for the tools, and when you return them you get your money back provided you keep your reciept, and you return them within 30 days.
You'll want to get
torque wrench
A - "1 5/16th" in socket.. I used a 34mm it was a little loose, but worked. I installed MOOGs, and I think the old ones came off with a 1 1/4 inch socket, but the replacement used a slightly larger nut. I couldn't find a 1 and 5/16 inch socket on the spur of the moment.
ball joint press
hammer puller
spindle nut puller adapter so that you can pull the spindle with the hammer puller
air tools make the job easier.
a work bench with a vice is also helpful
You'll have to pull your locking hubs out, for mine I needed this tool
For tips, please see posts 1,9, and 10 of this thread
http://broncozone.com/forums/index.php?s=&...ost&p=77878
