According to some guys who know this stuff in and out;
Computer - You must get a 5.8L computer from a truck just like your 5.0L. If you have a E4OD transmission you must get a 351 computer from an E4OD truck. You should be able to get this off a junkyard truck just like the intake. Just don't get one that was on a flood damaged vehicle .. by RRyan M
Is that 5.0 Police... a swapped in engine?
because of TFI issue..
Wiring harness... if TFI is mounted on da distributor and the 5.8 replacement has TFI mtd on inner fender near driver side hood hinge; you'll need to entend harness to it..
& if Both are EFI & EECIV.. the 5.8 isn't a 96 w/OBD II, the current harness should be ok considering the TFI
