bad gas...??
bronco410w
jersey
i went to the gas station "WaWa" and i was on E... i parked , turned off the motor , and got 40 of mid grade " 89 octane "
i went to start it after i paid , and it kept cranking but didnt start.... i did it 3 times ... then i got out kicked the gas tank 2 times.... got back in and it started right back up....
now i drove around for about a hour, i was driving it normal and also got on it a couple of times on the hwy... it felt just fine.... i also turned it off 3 times and it started right back up...
my guess its a lil bad gas, or air in the line... or its the first sign the pump is going...
what do u guys think?
yo!
Aside from FP Filter
Could have gotten the in-tank filter (also ref to as a sock) @ pump housing bottom filled w/rust and sludge for a moment
And, the WaWa gas in iffy IMHO... developed a nasty ping due to accumulated carbon.. and MUCHO carbon build-up in EGT Valve, TB,DPFE Hose, etc.
So, we went back to Texaco/Shell now
Read this info;
TOP TIER Gasoline Retailers; Gasoline retailers must meet the high TOP TIER standards with all grades of gasoline to be approved by the automakers as providing TOP TIER Detergent Gasoline. READ MORE at Site
Another poss. if it occurs again; ck FP/Fuel Sender harness/connector on top of tank; can carefully cut a floor pan section out to get to it and cover with same cut piece plus...
Cut-out Measurements for Fuel Pump/Level Sender Replacement by our pal Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums
Source: by toptiergas.com
Sandoval_broncosauria
