BRONCADONK
ok guys bare with me. i have a 79 bronco 400m auto. the motor is all stock. i live in california so i need to get this thing smogged. i have spent countless hours sourcing all the smog equipment from my local junk yards. when i bought it the previouse owner had stripped it of anything smog related. the problem is it has never ran the way it should, it does run better just not smog worthy. now that i have everything i need to smog it i can't get it to idle. it has a rebuilt motorcraft 2150 from holly, rebuilt smog pump, new air check valve, new coolant temp switches, i've replaced the intake gasket four times( i suspected a vac leak), i even had the intake inspected and resurfaced along with the egr adapter. it also has all new ignition parts, plugs, wires, distributor, cap, rotor, coil, and ignition module. this past weekend i installed a carb off my jeep cj7 that i know works, so that ruled out the carb. the fuel pump is new, along with the fuel lines and filter. i have tried to tune it with all the smog, vac lines capped to rule out any faulty delay valves or leaks. i've sprayed carb cleaner looking for vac leaks and have found none. my compression is 150 on all eight cyl. i'm runnin out of ideas so my questions are, can a faulty egr cause a rough idle? even if it is disconected? what about a leaky brake booster? (it makes a woosh noise when i press the brake pedal.) vac modulator? i realy love this bronco, and i don't want to give up. please help me. oh and if anyone out there needs smog info i know way more than i ever wanted.
