Backup switch
Greg P
SE Massachusetts
I need some help with some wiring. At this time I have no back up lights on my 69 Bronco. I do have four wires with a plug coming out of the automatic transmission. I also have a seperate piece of wiring harness, with approx 8 wires and four that has a plug similar to the one coming from the trans. Also on this section of harness approx 2 feet from the plug is the remains of a switch,that I believe is the backup switch. At the end are several other plugs that I believe plug into the tail lights. Can anyone tell me if this is correct and if it is how is this piece of harness wired and where does it get power from? Also where is this backup switch located and how is it mounted, any pictures would be helpful. Thanks in advance for any help regarding this problem.
79' Buckin Bronco
