What I'm hearing is, it's a question of timeframe.ok back to the subject no fightin. does any one know if the thermal coated ones are as good as the ciramic
Coatings are NOT purely cosmetic. (you can believe that, but that would be belief in a fallacy)x said:A coating doesn't make one better than another. Coatings are purely cosmetic. If you want to keep the heat inside the pipes, put heat shields around them. If you want them to last, buy the ones made of the thickest material. If you want the best performance for the money, keep the stock manifolds.
I've gone back over this thread, and I did not see that quote. Maybe you were the only recipient.x said:Xxxxx:
I would have to agree with that not only from what I have heard, but also from personal experience. Going a little bit over stock will not hurt a thing. As a matter of fact, FORD has been know to not only under rate their horsepower/torque ratings to keep the EPA happy, they are also famouse for "tuning down" their motors to do the same. Simple mods like a mild exhaust, in my opinion, not only sound better, but will increase performance. The trick is not to go overboard, know what you have built, and what will work with it. A mild cam and a few mild mods on a Ford small block will benifit from a increase in the flow, just as long as you dont go crazy. Oversized exhaust on a motor will cause nothing but grief. Hope this helps someone......Great explaination Joe, Thanks.Following your explaination, would it be fair to say that headers installed on an engine would help produce more power as long as the corresponding changes are made to assure the proper mixture is maintained?
These changes to the exhaust system should be coordinated with the fuel delivery system, and ignition systems.
it rly has help thankyou but all thight fight was very funny tho. and i guss im goint with the thermal coasted ones there 280 and will hopely last.I would have to agree with that not only from what I have heard, but also from personal experience. Going a little bit over stock will not hurt a thing. As a matter of fact, FORD has been know to not only under rate their horsepower/torque ratings to keep the EPA happy, they are also famouse for "tuning down" their motors to do the same. Simple mods like a mild exhaust, in my opinion, not only sound better, but will increase performance. The trick is not to go overboard, know what you have built, and what will work with it. A mild cam and a few mild mods on a Ford small block will benifit from a increase in the flow, just as long as you dont go crazy. Oversized exhaust on a motor will cause nothing but grief. Hope this helps someone......
