Thanks for the info. The only question is that Tee or block doesn't have threads at the top. How does the diff. vent connect to the Tee? I did find one like in the JBG link you posted but it won't thread down into that Tee. The old one I had, before it got lost I believed had some sort of prongs on it for tension and just pushed down into the top hole of the Tee. I got a 77 uncut and I had my rear leaf springs rearched and had a extra leaf installed also along with a rear 1" block for some added lift in the back. I think when they lifted the body for the block that piece didn't get installed properly and then came out. Do you think the one that JBG has will work? How about the Tee will I need to replace that also so the new vent will thread into it?
Thanks,
