Renegades8
Do you have to change gears if you buy new axles
It’s 1988 Bronco I am seeing some unusual wear on the spline on drivers side. My intent is to put new inner and outer bearings front and rear clean up under carriage and paint. Putting on 6” lift kit 18” rims 35x12.5 tires interior has new racing bucket seats diamond tuck interior bought a plastic mold headliner with speaker system built in neon head light rear tail light lens dark windows tinted having the truck repainted pearl white with rolling ghost flames did some small motor work so far has a 351 Windsor so far performance chip air intake changed looking at turbocharged. Body is in perfect condition. Gentlemen bought it passed away and sat in garage for years. That’s my story. Back to axles I am looking at a new set 9” factory spec after market.You don't have to.
You can buy axles with the correct or your desired gear ratio unless you are running something really unique.
Are you looking for standard replacement?
What are you working on?
Sounds sweet!It’s 1988 Bronco I am seeing some unusual wear on the spline on drivers side. My intent is to put new inner and outer bearings front and rear clean up under carriage and paint. Putting on 6” lift kit 18” rims 35x12.5 tires interior has new racing bucket seats diamond tuck interior bought a plastic mold headliner with speaker system built in neon head light rear tail light lens dark windows tinted having the truck repainted pearl white with rolling ghost flames did some small motor work so far has a 351 Windsor so far performance chip air intake changed looking at turbocharged. Body is in perfect condition. Gentlemen bought it passed away and sat in garage for years. That’s my story. Back to axles I am looking at a new set 9” factory spec after market.
