Annoying Squeek At Low Speeds
badassbronc722
hello everyone, I have a 1996 bronco and I just put it in 4wd the other day for the first time since i bought it, it was insanely dusty and now there is a low speed constant squeek that is driving me nuts, its no the brakes or trans what else could it be.....i have sprayed lithium grease on the hub seals on the inside where the shaft goes to the hub thinking that that was it but still there.....any ideas
thanks
BigNasty
SquirrelBait
NC
Run over a squirrel?
Maybe it's haunting the truck :D /emoticons/[email protected] 2x" width="20" height="20" />
And it was rather rude of you to call him a joint... :D /emoticons/[email protected] 2x" width="20" height="20" /> :D
Are you sure the hubs are disengaged. If they are not actually disengaged, you may be hearing a frozen axle bearing cutting it's way thru the axle.
Windchaser
Topeka, KS
sweepersrgr8
"GET ER DONE"
Charleston,SC
Put the truck on jack stands ( all four corners), lock the hubs, shift into 4WD, and get under there to find the squeak.
My bet is on U-Joints being the stock ones are non-greaseable.
88pimpin
Postwhore, Pimpin Ain't Easy
Bozeman, MT
Since we're having a related comment, I have a problem with my Bronco:
I get a clicking sound from the front passenger's side and from the rear driver's side. A friend of mine with an 86 F-150 said the front passenger's could be the speedometer cable, but didn't really know what the rear driver's one would be. They both happen with every full wheel-rotation. Front one I notice when I drive by a building or something with my radio turned down, but the back one is over twice as loud and sounds crappy.
felixb52
