AIR pump and EGR fix? Also what is this?
harbinger
Previous owner removed air pump and let the EGR tube rust in half. Also I've been working on setting the vacuum back up the how it should be. I've done a good bit of research, but I think it's time to enlist the pros.
Green vac line goes to EGR, not vac tree. Correct?
Where are the holes that need to be plugged for the AIR/smog pump?
Here are some pics of the suspects.
Right above the starter?
Are they on the back of the heads?
Above is on the driver side above the transmission. Below is the passenger side right above the transmission dipstick tube.
And can anyone identify this wire or what it should be connected to?
yo H,
yes, green to EGR as shown below;
Vac hose R&R in 89 F 150 (same as Bronco)
Source: by Booba5185 http://fullsizebronco.com/forum/showthread.php?t=192382
and more info in my Vac Leak Test at http://broncozone.com/topic/23994-90-58l-getting-continuous-code-33-and-running-code-44/ post #11
Stainless Steel Thermactor Smog Plugs the holes in the back of your cylinder heads when removing the exhaust crossover tube. Comes with 2 stainless plugs and Loctite. Hex head makes installation easy when the engine is still in the vehicle.
http://cdn.shopify.com/s/files/1/0063/4532/products/thermactor_plugs_large.jpg?100386
Bruno wrote about these; "...the diameter and thread pitch is 5/8-11. I went to the bolt shop and bought 4- 5/8-11 x 3/4" stainless steel bolts. The cost was $7.29. A person could get off quite a bit cheaper if they could find just a regualr grade 5 in the same configuration and either paint them or leave them *****. I would assume this could have been for $2-$3 if I went that route. I used ARP thread sealant on the threads. I used the same sealer(reccomended by ARP) to install my rocker studs in the heads. So I am assuming it will hold up. If not Loctite makes a thread sealant used in boiler and hydraulic applications labeled 545. This stuff is much thinner and is very similiar to the consistency of their thread locker product. I went with the ARP sealant b/c the thread pitch is so coarse on these bolts I was worried it wouldnt seal well.
The only thing I would say to watch out for when doing this is to not crank down on the bolts with a lot of torque. The location of the thermactor port is over to the side of the head and isnt very thick there. It looks as though a person could break the head very easily and open up a can worms. I tightened mine down with an end wrench. The head was a 15/16". If I had to guess at how much torque I put them under I would say 45-50 ftlbs .
Good luck! The bolt size is a little uncommon as far as the thread pitch goes. I have a fastener supplier that I do a lot business with and they had them in stock. I considered using a set ***** with the same dimensions , but , the machine supplier only had them in 3-1/2" lengths. I used a set of calipers to measure the depth of the thermactor port before I explored my options. I did this so I wasnt limited to one length and it increased the chances of finding something that would work. The port depth measured out to be just a little longer than 1-1/2" maybe 1-5/8". I would assume a 1-1/2" length would work as well.
351 and 302 heads are reversible. In other words there is no left or right head .So there is thermactor port on both ends of each head as well as threaded holes for the accesories on both ends.
I ran the bolts in and out while blowing the hole out with the compressor and blow gun. Then wiped the doo doo off of the bolt before applying the thread sealer..."
SOURCES;
EGR Tube (also called, AIR Tube), Crossover Tubes, Check Valves, O2 Sensor Repair Bungs, High Temp Silicone Hose, etc. for Bronco & all Ford, w/Ford Part Numbers & pics; miesk5 NOTE; "...EGR, Source: by PCI Inc
great customer servcice!! they see direct or thru NAPA..etc.
http://www.pciinc.com/
Maybe someone else can reply to other Qs such as pump bolts;
H
harbinger
I like the part about the doodoo. anyway, I can't seem to find the location?  am I on the right track with the photos above? are the holes on the sides or the rear of the heads?
yo H,
two ports on the back of the heads see - pic below.
Diverter & Bypass Valves, Hoses, Crossover Tube, EGR Valve, PCV Port & Smog Pump Location pic in an 88 F 150 5.0
Source: by Steve
Typical EFI Vacuum Lines (V8 shown; I6 similar)
NOT SHOWN: pre-'93 vacuum cruise servo, brake booster hose & check valve
For colored hard plastic vacuum lines:
RED is the Ford standard color for manifold vacuum
BLACK (hard plastic only) is the Ford standard color for checked or reservoir vacuum
PINK is the Ford standard color for TAB
YELLOW is the Ford standard color for TAD
GREEN is the Ford standard color for EGR
WHITE is the Ford standard color for the fresh/recirc door for the HVAC system
Early 2-port HVAC check valve shown. Most trucks use a 3-port check valve that connects to the HVAC reservoir.
Smog Pump pulled showing bolt holes
These holes?
Yes,
Unless someone else with 86-91 Bronpo has other info; Ford mage changes to Secondary Air System through years; such s in 96 where 5.0 had smog pump, TAD/TAB solenoids, valves, etc. but 5.8 did Mot have Secondary Air sys because of model year engine/ emission improvements
The upstream air (going to the heads) pre-burns some of the fuel coming out of the exhaust ports, and helps generate enough heat to get the cats working. The downstream air (going to the cats) provides Oxygen & Nitrogen for them to work.
H
harbinger
Awesome. I don't think I'm going to reinstall the air pump so I'll just plug them... unless they already are. How bad would that be to drive around with those holes wide open?
yo H,
I see you are here in this thread, so instead of editing thus you possibly missing the edit;
Check TAB and TAB solenoids next to Coil; some use the elimination resistors when bypassing the Air Sys.
also;
look for this EGR Eliminator & TAB/TAD Eliminator;
http://web.archive.org/web/20070221131457/http://rjminjectiontech.com/?p=9
http://web.archive.org/web/20131107051157/http://www.rjminjectiontech.com/
"Remove the EGR for a cleaner look and cooler intake air. The EGR system adds heat and carbon deposits to the intake manifold. EGR Valve Position Sensor Eliminators send a 0.50volt CLOSED EGR signal to the computer. The computer then knows the EGR is permanently closed. Keeps the annoying CHECK ENGINE light OFF, and more importantly keeps the engine running smoothly. Guaranteed to work on any 1986-93 5.0L Mustang! Also works on most 1986-95 Ford that uses the Light Gray EGR valve position sensor; which has a closed reading of 0.24 – 0.67 volts. Without this the computer will assume the EGR is stuck open when removed, causing a rough running engine. We can't guarantee these will work on every 1986-95 Ford, but the only other option is a custom chip for the computer, which typically costs $350 or more. While the only option for 1996 and newer Fords is a custom tuned chip for the computer.
Made with original Ford parts that plug into your stock wiring harness EGR Position Sensor connector under the hood."
by Ryan M - he is out of business now so just showing his former site for info only
