You really dont need the intank fuel pump...... the pressure pump is plenty... if it goes out you can take the pump out completely (to avoid restriction in the lines) and just run a fuel line from the rail on the sending unit to the botom of the tank....
TO BLEED THE SYSTEM: Its easier to do it if you have help/// have some one depress the valve on the fuel rail with a MATCH STICK while you prime the pump,,, just turn the key from off posetion to koeo,,, you should hear the pump running for a few seconds then cuts off..... just do this on/off cycleing untill fuel squirts out of the rail.... then you should be good to go.....
i would test your old intank fuel pump with two wires directly to your batery if it does anything then its probably good... but its probably not worth pulling ur tank again?!?!?
Hope it helps
