Air Filter / Distrib collision...
monza
San Francisco
hey,
I have a '75 351 conversion with a Holley Street Avenger 650 4 bbl sitting on it.
The problem is the recommended 14" diam air cleaner collides with the plug leads on the distrib cap - so it wont seat properly...
I cant use a seat extension collar because the cleaner is already bang up against the hood (WH Classic Scoop - a big scoop).
Anyone got a fix for this problem ?
I was thinking of swapping out to an oval air cleaner - but heres the silly part - i dont know if oval cleaners are supposed to run front to back (which will still hit the distrib), or side to side, which will clear the distrib.
so there u go
i know a bunch of you guys have Holleys on 351's
so how are you getting the air cleaner to seal.
thx, Monza.
I had the same prob. with the edelbrock.....(& no hood scoop)
It hit the hood (but not the dist.) When I installed thinner spacers under the carb...the bottom filt. plate hit the throttle linkage.
Honestly, can't remember how I solved this BUT, had I known about an oval filter & housing, I would have done that in a heartbeat..!!
The carb. doesn't care how it (filter) sits on there.....even on a 45 deg. angle would be fine. If it will fit & clear...go for it.
monza
monza
San Francisco
I had the same prob - - Honestly, can't remember how I solved this BUT, had I known about an oval filter & housing, I would have done that in a heartbeat..!!
OK Bro'
Funky Filter time.
Thx, Monza.
79' Buckin Bronco
