Add a leaf question
michibronc
Flint, MI
is typical from adding a leaf? Is it possible to get 2"? I figure it's bound to be more than the thickness of the leaf.
1-2 inches for most, depending on the spring rate or stiffness of the AAL.
michibronc
michibronc
Flint, MI
Will I need to change the shims if I raise the rear by 2 inches? Is there a certain amount of lift for the rear to where you need to change shims?
Bronc76
with only 2" you shouldnt have to change the shims
rcarm74
