ABS Light
Abyss672
Wayne,NJ
This morning i went out for breakfast and came home then went to leave a 1/2 hr later and the abs lights was on and i have no speedo or odometer what would be the Cause and also my gas gauge sometimes works its an 94 5.0 Eddie bauer Bronco
Thanks, Matt
50joe
Trenton NJ
I'm assuming your talking about a 92-96? If so, it's most likely the speed sensor in the rear. It is located right on top of the pumpkin. Go bad quite frequently. Its a pretty inexpensive part, I think around $15-20 or so. If I didn't have a code reader for the ABS, it's where I would start.
broncosam43
upstate new york
Also it could be just a blown fuse ive had that happen too or maybe a bad relay id check thouse as well there are two fuse panels one under the hood the other one is on the drivers side theres a little panel there ive had a fuse blow there before
A
Abyss672
Wayne,NJ
I tried the vss first cause it looked shot and it was worth replacing but it did nothing and i start to do some research and i found the issue with the POSM and i saw i had alot of the issues that were related with that so i looked for fuse d and couldnt find it but there was only 1 15 amp so i pulled it and it wa poped so i replaced it and the whole thing was fixed so thnxs guys for the help
denny.dikes
