Thanks for the inspiration...lol Not exactly my cup of tea, but at least the person put some effort into it.
I forgot to add about changing the fuel tank and pickup to a non efi version. And I guess I will need a different dist if I start off with the efi block. I may just go with an msd or mallory dist and matchin box. As far as suspension stuff, I'm thinking about stock height, or maybe an inch or two lower, with poly bushings and larger sway bars to stiffen it up. The tires will be a little lower, but wider, profile tire for traction. I have 235/75-15 and was thinking about a set of 285/60-16's on some new Ultra Type 164 16x8" rims.
I think I will keep the 4wd...would be a shame to hack my truck up for nothing...it does snow here every once in a while.
As far as the 351 goes, I'm thinking a mild build in the 300-350 lbft range turning around 5000rpm max. Any suggestions on this. Most of the 351 builds I see are designed for high RPM drag mustangs. This will be a fun street truck after all, so I'm concerned more with a good takeoff and steady power build more than top speed. This is a bronco and I'm NOT planning on cruising at 100+, but I like to have my neck snapped on a good takeoff. A 5-speed with 3.73 gears should give me the take off and still be able to cruise at 70 on the freeway. I'm not really concerned with gas milage since it only got about 10 mpg with the stock 5.0. I should be able to reach my power goals and still hit 9-10mpg when driven normally.
On a side note, my new company car is an 09 Escape with the 250hp V6 6-speed. Man that thing is quick for a factory mini SUV. I'll have an unofficial 0-60 in the next few days.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
/emoticons/
[email protected] 2x" width="20" height="20" /> I'm guessing its in the upper 6 sec range...good enough to whoop up on the ricers around here.lol
