My '86 Bronco has an A/C with a fixed orifice tube. The pressure switch is supposed to be set so that the compressor cycles to keep the evaporator from freezing up. There is nothing on this truck to read the evaporator temp., like on earlier ford trucks with an expansion valve and a temp. sensor in the evaporator.
The pressure switch is adjustable with a ***** driver, but the plug has to be pulled to access the adjustment *****. Is there some sort of jumper that would allow one to run the compressor while turning the adjustment to get the correct cycle rate, and what is the right cycle rate. I have adjusted it by trial and error, but as you lose refrigerant over time it needs to be adjusted to keep the cycling rate from being excessive. There ought to be an easy way to adjust the switch with the A/C running. Anyone know how this should be done?
