Okay boys,
First of all nice forum. I have a couple and know where to find info I can't figure out. Here it is and lets see what you think. I am out of ideas.
A customer brought in a 96 for Bronco with a 5.8, the issue is that at idle the truck is fine. But the ECT sending unit guage will spike. Like 90% and then go back down to half.
The Data port on the scanner says 156-175 when it does this.
So I checked the guage by grounding the wire and if went full, did this a couple times.
Water flow in radiator is flowing well, it was brought into me after the heads were done. The guy said it overheated and quit. I am unsure if this was the safety shutdown for the head temp or not.
It has a new water pump on it. It doesn't look like a motorcraft or any name brand I am used to seeing.
I took readings with a infared and the head temps never went above 180 even when the guage spiked.
I installed a mechanical sun pro temp gauge to see if that was it. Nope.
The sun pro will sit at idle about 190 which Is good. Then it will spike to 215-230 and then go back down.. to 190 and continue to do this.
The truck has some lifter noise even after this customer got the truck back from the guy who did the heads for him. But it goes away after about 10 minutes of running. This motor only has less than 100 miles on it since the heads were done.
So since all I did was rant.. this is what I have replaced.
1) ECT
2) ECT sending unit.
3) New motorcraft Thermostat
4) Removed the sending unit and installed a mechanical temp guage. (tonight) still spikes
Other than the spike on the temp it runs pretty good. Flew through smog.
This truck doesn't have any special burb procedure does it? I mean it is still a pretty basic system. I don't think the water pump could be doing this?
The top radiator was averaging about 140 and the bottom was 120-130. The thermostat housing stayed pretty close to the scanner readings about 170-190 even when the dash gauge and the mechanical aftermarket guage spiked. The scanner did not spike?
Confused ? I am
Thanks again for any input.. I will check tomorrow.. when I get to go try and fix this beast..
Nothing I can find on IATN or Identifix..
Spud
1) ECT
Confused ? I am
Spud
