96 bronco 351w e4od
ed351bronco
hello there im new to this and i would love to see if i can get some helpful info i got a 96 bronco xlt 351w and a e4od i have rebuilt the motor due to a piston slap so i said lets just do some extras bored 30 over roller rocker heads mild cam msd ignition k&n air intake jba headers. by the way ran great even with the #7 piston slap now i have a tranny poblem and a timing problem tranny kicks when it takes off and kicks down ******* stop too and it feels like i have the parking brake on felt better before i did all the new stuff. I get super crappy mpg and i the timing idles real low i know this is comp controlled. i have 35" tires with 4:10 gears had that before and it ran great im thinkin its a sensor prob any help would be great. oh and tranny was rebuilt before the motor. thanks guys
yo ED,
WELCOME!
Please take it to a local parts store that does Free scans for Diagnostic Trouble Codes (DTCs); Advance Auto, or a mom & pop shop, AAMCO...etc.
I run it around to heat the engine up and shift thru all gears incl Reverse.
then; turn off all accesories/lights, etc.
Have them Do KOEO portion first
For Key On Engine Running (KOER) portion, the engine has to be still @ normal operating temp.
If they say the KOER isn't necessary, ask them politely to do it anyway.
Post any codes found here or look em up in my broncolinks.com site in the Search feature
If you have or know anyone that has a timing light; Check Timing;
Adjustment in Ford EFI Engines
Source: by Ryan M (Fireguy50) at http://fordfuelinjection.com/index.php?p=71
Of course there are more that could be tested; do that stuff first
GL!
E
ed351bronco
yo ED,
WELCOME!
GL!
E
ed351bronco
hey miesk5 whats up man,
i got a p0420 code catalyst i had the cat on and it was doing this i took it off gave me more uummppphhh but still the same i looked on the link and it was directing me towards replacing or reprogramming pcm? do you think that would work im almost bald from all the hair ive been pulling out to find this problem.
yo Ed,
Sorry for the delay; Comcast finally figured that their underground cable box next to the Lake here really wasn't a good idea!
So, they pulled it all out, thru the wookds all the way to granny's house.. but never came back..lol; So I am on da road and won'r have *** PC cable access for awhile; or maybe never again...
Look at this instead of touching the PCM
DTC P0420 Catalyst System Efficiency below Threshold (Bank 1); Symptoms, Causes & Possible Solutions;
Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
Source: by obd-codes.com at http://www.obd-codes.com/trouble_codes/generic/p0420-catalyst-efficiency-below-threshold-bank-1.php'>http://www.obd-codes.com/trouble_codes/generic/p0420-catalyst-efficiency-below-threshold-bank-1.php
& then;
DTC P0420 - Catalyst System Efficiency Below Threshold (Bank 1); "...( Indicates Bank 1 catalyst system efficiency is below the acceptable threshold;
Use of leaded fuel
Damaged HO2S
Malfunctioning ECT (were both KOEO and KOER tests done so this can be ruled out since there isn't a DTC for the ECT?)
High fuel pressure
Damaged exhaust manifold
Damaged catalytic converter
Oil contamination
Cylinder misfiring
Downstream HO2S wires improperly connected
Damaged exhaust system pipe
Damaged muffler/tailpipe assembly
******** spark timing
Compare HO2S upstream & downstream switch rate. Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage which makes the switching frequency of the downstream HO2S quite slow compared to the upstream HO2S. As catalyst efficiency deteriorates, its ability to store oxygen declines and the downstream HO2S signal begins to switch more rapidly approaching the switching rate of the upstream HO2S. Once beyond an acceptable limit the DTC is set.
Source: by slingblade
I can't copy the all da possible reasons / info @ http://www.obd-codes.com/trouble_codes so go thru the eziest and cheapest tests first by slingblde and them, such as checking for an exhaust leak(s)
For the CAT leak - look at the air tube to da cat from the Air Injection Systems check valve behind engine near firewall; the valves and it's tubing rust out .. mine ck valve rusted out @ 70k miles;; esp listed for an exh leak sound while aceelerating.
Ck O2 sensor(s0 Wiring and connectors; corrosion. shorting out
Identification & Location; "...Regardless of how the engine is mounted in the vehicle, conventional or transverse, the HO2S naming convention stays the same in relationship to engine banks 1 and 2. Bank 1 will always be the bank containing the #1 cylinder (Passenger Side). Bank 2 is the driver's side. Sensor 1 is da upstream sensor, between the engine & the catalytic converter. Sensor 2 (DOWNSTREAM) is after the converter (it is actually monitors the catalytic converter's eficiency) See Fig. 1 in TSB 01-9-7..."
Source: by miesk5
Location in Exhaust System Parts Break-Out Diagram in 96 5.0 & 5.8; "...HEGO=Heated Exhaust Gas Oxygen; sensor=HO2;S Your truck has 3. The front ones are labelled "F" in this diagram, & the rear one is unmarked directly below "4"..."
Source: by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/72365_1
DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY - 96 Bronco, TSB 01-9-7
Source: by Ford via v8sho.com @ http://www.v8sho.com/SHO/TSB0197HO2SServiceTips.htm
See DTC and Diagram; acronyms snd abbreviations for all this stuff.
Air Inlet Tube Location at Catalytic Converter in Exhaust System Parts Break-Out Diagram in 96 5.0L & 5.8L & F-150, F-250, F-350 Regular Cab, SuperCab and Chassis Cab, 4x2 and 4x4, 4.9L SFI, etc..; use your Browser's SEARCH (or FIND) function to locate what you seek in each Diagram, such as Air Inlet
Source: by Ford via thedieselstop.com @ http://www.thedieselstop.com/faq/9497faq/maint/stj/stj90015.htm
Let's see if I can post the image here; if not go to the site and view it;
Item Part Number Description
1 5F250 Catalytic Converter Assembly
2 391104-S2 Stud, Catalytic Converter-to-Exhaust Manifold
3 375636-S309 Nut, Catalytic Converter-to-Exhaust Manifold
4 9J454 Air Inlet Tube
digs
