96 anti lock problems
Baxwell
Every thing works fine until it rains, then the ABS light comes on and the speedo needle would jump when you hit the brakes. After a few days of dry weather the system would return to normal. We got 12 inches if snow about a month ago and DOT dumped all the salt they owned I think. Since then the ABS light stays on constantly. I replace the sensor in the rear end and found a bare spot in the harness where it rubbed through on the frame, this did not fix the problem. I have scanned it with my MT2500 and it comes back with nothing. Anyone have any experience here? I think maybe it is the module, but that seems like a pricey guess at the Ford store. Anyone have a module they want to part with.
Thanks for any help,
Brad
texan79&96
what all years can the module work off of? my 96 abs act up if the fluid gets a little low sometimes. i dunno where your at but you should check out some junkyards i saw a 94-96? bronco in one today it was crazy rusted must be from the north or somehtin.
Welcome to the Zone > Post some pictures in the Introductions section. This post should actually be under Tech Support so I am moving it. :) /emoticons/[email protected] 2x" width="20" height="20" />
