95 bronco rear seatbelt roof mounting parts
jshoney
My 95 bronco had the original rear seatbelts cut and the roof hardware removed. I purchased a set of good used belts with everyting except the hardware thats inside the removable roof. On one side the bolt is still in the roof but it just spins and I dont know how to get it out and the other side there is just a hole. Can anyone tell me or post a picture of what the roof mounts are supposed to look like and where to get or how to fabricate new ones if that is even possible! Thanks
It sounds like the hardware came loose and is probably between the two layers. Without cutting open the cap, I don't know how you are going to get the hardware between the two layers, that is if you could get the hardware. You will probably be better off getting a cap off another Bronco. I know it could be done, but definitely not worth the time and effort.
Like Steve83 says, get a new one and use it to make something like this, or a bikini top.
digs
