Hello!
I just aquired a 95 Bronco with 351w. The previous owner told me it had overheated, made some noise and never ran since, thats about all the info I got. When I got it home I tried to start it and it wouldn't even backfire. I'm assuming its the heads and/or gaskets. I haven't did a compression test yet but it sounds like it has no compression when turning over. Anyway, is it easier just to pull the engine to remove the heads? I'm not sure what else this motor might need, ODO reads 225,000 don't know the history of the motor. PVO also said she might have heard it knock when over heated, didn't see any metal grit in oil, but it has had a year to settle. Thanks for any input!
