94 Eddie Bauer Air Cleaner Hardware
killerklown
Wisconsin
Does anyone know the proper size of the 3 screws that hold down the air box? I'm removing an aftermarket filter setup and need to fasten down the OEM box.
Yo K,
Call and ask local Ford dealer Parts dept.
Ask for N611062-S2***** and Washer Assembly (3 Required)
If none;
Contact:
Following for a 96 Bronco
ItemPart NumberDescription
19B659Air Cleaner Outlet Tube
29B647Lower Air Cleaner Outlet Tube
3Hose Clamp (Part of 9B647)
49600Engine Air Cleaner
5N611062-S2***** and Washer Assembly (3 Required)
616005Left Fender
7N610958-S2***** (3 Required)
89626Engine Air Cleaner Mounting Bracket
9388577-S150Pushpin (2 Required)
109A624Engine Air Cleaner Intake Tube
119E926Throttle Body
12Hose Clamp (Part of 9R504)
ATighten to 1.5-2.5 Nm
(14-22 Lb-In)
BUse Water or Rubber Lubricant D9A2-19583-A or Equivalent to Facilitate Installation of Hose Assembly to Throttle Body
CSurface Must Meet Against Throttle Body Stop ****** for 360 Degrees
(Both Tubes)
DWater Bottle Affixed at This Location
