94 bronco tranny
markinark
Arkansas
How many different trans did they use in the 94 Bronco? I have the pushbutton O/D on mine. What were the options and what would mine be?
The 89-96 Broncos used the E40D auto tranny, so your 94 would have that model. JSM84
yo, Good stuff JSM!
AOD, C6 & E4OD Identification; "...If the shifter has a P-R-N-OD-D-1 pattern, the transmission must be an AOD.
http://img.photobucket.com/albums/v663/RampageFSJ/a4-1.jpg
pic by trigger
If it has an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, then it is equipped with an E4OD transmission..."
Source: by Baumann Electronic Controls, LLC
is actually a (D)in a white circle
http://www.supermotors.net/getfile/117390/thumbnail/picture-011.jpg
pic by Chris A
Trans code: E
P-R-N-D-2-1, shifter pattern, it is a C6
Trans code: K
http://www.broncolinks.com/gallery_images/C6ShiftIndicatorpic.JPG
pic by miesk5 at broncolinks.com/gallery
I sense you intend to swap another tranny in there? If so, look @ my site @ http://www.broncolinks.com/index.php?index=63
5.0 Broncos in 94 had either the E4OD or the Mazda M5OD manual
There may have been very few w/ a left-over AOD though and some say these Broncos were for Local/Natl Govt use
for swaps from E4OD to:
Auto:
4R100
4R70W
C6
Manual:
M5OD
ZF Swaps are @ http://www.broncolinks.com/index.php?index=55
