yo!
Do a self test for Codes;
by my buddy here, BroncoJoe!
http://broncozone.co..._mode__threaded
important noted from Joe's diy article;
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Make sure A/C is off and transmission is in Park (automatic) or in Neutral for a Manual & release clutch
There are two types of EEC Self-Tests, Key On Engine Off (KOEO) & Key On Engine Running (KOER).
The engine temperature must be greater than 50°F (10°C) to pass the KOEO Self-Test and greater than 180°F (82°C) to pass the KOER Self-Test.
Post Codes here or look em up in my site using da SEARCH feature.. some Codes will be repeated a lot bec. they are used in different sections of my site... type ia code number such as 123
Remember that a code comes up for say.. DTC 87 FP relay circuit failure; may not be the relay itself..suspect inertia switch, fusible link, FP relay or EEC relay &/or socket corrosion, etc. so save $ on parts replacement for now until codes are checked and analyzed.
Next is, if needed would be a fuel pressure check, read and see how to Test pressure at the fuel rail with a gauge
the 5.0L, 5.8L and 7.5L EFI engines in-tank mounted high pressure fuel pump is capable of supplying 105 liters (27.7 gallons) of fuel per hour at a working pressure of 270.0 kPa (39 psi).
Pressure During KOER Self Test; 4.9 (45-60 PSI), 5.0 (30-45 PSI), 5.8 (30-45 PSI) & 7.5 (30-45 PSI); read more for KOEO PSI Source: by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/clubs/superford/vehicles/registry/media/283459_1
see diagram on how to run fuel pump using same DLC connector that BroncoJoe describes in that self test for Codes.
here it is
http://www.supermotors.net/getfile/245234/thumbnail/dlc-eeciv.jpg
Connect FP Relay (terminal A) to any ground to force the fuel pump(s) on when the key is in RUN.
