93 bronco door lights
lovemy93
any one ever remove the courtesy light fixture in the doors of a 93 bronco? I went to replace a bulb and pushed the light socket through the fixture......I was hoping I could remove the fixture without having to take the whole door panel off and re insert the socket......Im pretty sure Im going to hear cant be done but I thought it was worth asking .....thanks in advance
yo, WELCOME!
96 Bronco-F-Series Workshop Manual (PARTIAL)
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Same as most earlier years especially 92-96, excepts for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
Section 17-02: Lighting, Interior
REMOVAL AND INSTALLATION
Lamps, Courtesy
Door
Removal
1.Use a thin, flat-bladed screwdriver placed into a notch at the front edge of the courtesy lamp lens, then gently pry rearward and up to remove the courtesy lamp lens.
2.Remove the miniature bulb (13466).
Installation
1.Replace bulb and position rear edge of the courtesy lamp lens into the housing and snap into place.
yo, This was omitted; sorry
Section 01-05: Trim, Interior
1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
http://www.diesel-dave.com/vehic/manual/stj/stj15008.htm
Trim Panel, Door
Removal
1.Remove *****(s) retaining the front arm rest pad (24100) to front door trim panel (23942).
2.Remove ***** retaining inside door handle (22600). Remove inside door handle.
3.Remove the ***** retaining window regulator handle, if equipped. Remove window regulator handle and washer.
4.If equipped with power windows, remove window regulator switch housing (14527). Refer to Section 01-11.
5.If equipped with power door locks, remove the power door lock switch housing. Refer to Section 01-14A.
6.Remove door lock switch (14028), if equipped. Refer to Section 01-14A.
7.Remove outside rear view mirror control (17B676), if equipped. Refer to Section 01-09.
8.Carefully pry front door trim panel and pushpins away from front door trim shield (237A04), using Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent. Never pull on front door trim panel to remove pushpins from front door trim shield.
Installation
1.Follow removal procedures in reverse order.
2.Tighten ***** and washer assembly 1-2 Nm (9-18 lb-in).
see diagram
lovemy93
lovemy93
[SIZE=14.0000009536743px]thanks for the response...... .so the plastic light  fixture housing( not the lens ) doesn't come out without taking the door panel out ??..there is a notch on one side that looks like you might be able to pry it out from the front but I don;t want to break it If it wasn't meant to come out that way . Just seems to me that it should come out ..........thanks again..................I hate shit that doesn't work on my truck [/SIZE]
lovemy93
lovemy93
I see now the door panel has to come off........thanks again for the help
Lana Kane
