Ok so i have a 86 full size with a 302 efi. I have prob i nor any other techs who helped can figure out. I will attemp to explain theproblem and symptoms. But please dont let how i explain the symptoms pidgion hole what is actually the prob. And then i will tell things i checked also codes.
The biggest symptom is when driving and u get to about 45 or 50 mph when i let off the gas completely the truck will kinda bog back and fourth between free coast and a sensation that feels as if i lost all spark or like engine braking or torque conv is locking and unlocking (no pidgion holing. Just trying to best explain) this will happen till gets to like 20 or 25 mph and what feels like the trans shifts and goes back to normal
other symptoms that may or may not be related. Engine no longer goes into high idle warm up. Once started it has low irratic idle. Also vehicle always now holds irratic iddle. And once warm the idle is always high. In park its at 1300rpm . When does the back and fourth bogging u can smell excess gas. Every once in a great great while when starting engine will only turn and possibly has no spark then after 3rd try or so will fire right up as it always does. When idle ever gets low in park or nutral and then shift into gear engine will surge as if it is properly detecting load but trans doesnt go to gear right away. Sometimes when driving at various speeds it will like huge cough like momentarilly lost spark and give u one big **** and then all is ok.
Codes
koeo. 31. Egr (evp/ept) circuit out of range
koer. 44. Thermactor air system not working
koer. 34. Egr (evp) closed valve signal to high
koer. 13. Cant control rpm during low rpm check
Things checked and tried and changes noticed
checked for vaccume leaks with water and propane. None found at this time
pulled plugs#8 has a little oil and is darker then rest but is burning hot enough and is burning it all off no prob. But still i cleaned pluged and swapped it with #7 plug. Things changed.now 90% of the time instead of back and fourth bogging. When let off the gas now at same speed of 45 to 50 the truck will just do the same bog sensation as previously explained but now its just constant. No back and fourth. Untill bout 25 and kicks out like it shifted and all is ok again.
Replaced iac. No change.
All cylinders compression at 150 except #9 at 145. Top half of motor i rebuilt a year ago.
All plug wires new. Rebuilt distributor. New o2 sensor. New msd ignition coil. Replaced tfi when it went out year and half ago.
Cant tell if its engine or tranny or both
When truck is under power it does great. Plenty of power plenty of get up and go. Shifts good. Did power brake and slowly gave more and more gas and heard no miss fire.
Need all help as this is my daily driver and its killing me in gas worse than ever and switching jobs soon and need it dependable again.
Not to mention its putting a hault on my sas plans for next summer haha
Thank u for any and all help
Codes
