9'' o 8.8 rear end
audie.a
I have a 93 bronco and would like to put a 9'' in it..If i do is there a way to get around the abs sensor so that my speedo and everything else works?
I posted here somewhere about a shop that was taking the round bolt on ****** for the driveshaft on the back of the T case and machining slots in it that tripped a sensor mounted on a bracket so that they could use other rear ends in trucks that needed the speed sensor in the axle . Ill have to see if I can find the post . :D /emoticons/[email protected] 2x" width="20" height="20" />
A
audie.a
thank you very much,and im going to check it out and then post it...
guilhermeknob
