hooverg2424
Just wanting to know if anyone has advice for changing out my back bench for two buckets on an 89 full size bronco.Thanks all info will be great.hoov
find two bucket seats that will mount flat to the floor ( or bend the mounting brackets), mark and drill your holes through the floor(check first that you wont hit anything important) have decent washers on the top at the head of the bolt. then on the bottom get pieces of 1/4" steel plate cut at 2"x 2" you can either drill, then tap the plate so the bolts thread in, weld nuts onto the plate, or just use lock washers and regular washers on the nut side of things. and you will have solidly mounted bucket seats perfect for guided wild off road tours.
of course test fit to ensure space and comfort.
good luck
