89 bronco 4 wheel drive help
ccems
Hello, I just purchased my first Ford Bronco full size as a project truck. I have tried the 4 wheel drive out and neither buttons on the dash will light up or any indicators lights come on when the buttons are pushed. I do here some noise on the right side of the dash when the buttons are pushed. Either way the 4 wheel drive front diff is not engaging. Any help would be greatly appreciated.
Krafty
Ontario Canada
did you test out the bronco by driving around after pushing the buttons? if you turn on either dirt or pavement and the 4x4 is working you should feel the bronco **** and lurch. just wanna rule out if its just the lights.
check the wiring diagrams and fuses to try to just run down the basics. the first thing I suppose is to see if the circuits are getting power.
good luck
cheers
krafty
C
ccems
Its not engaging at all so I am guessing I need a wiring diagram for the 4x4 can anyone help me out where do I go?
Krafty
Ontario Canada
you'll have to refer back to the article for some of the Letter references from the diagrams
http://www.supermotors.net/registry/media/724137_1
DIAGNOSIS
Nothing Happens (Dead System)
The obvious first step in diagnosing a dead system is to check the power sources, fuses and grounds. If these check out, you should run the shift control module self-test. Figure 22 shows the module with pigtail "A," "B" and "C" attachments. The self-test button and self-test LED are located on the side of the shift control module.
Disconnect the "B" and "C" connectors, turn on the ignition and allow 4 seconds for the module to power up. Then push the self-test button. If the LED doesn't illuminate, the module is dead and must be replaced. If the LED comes on and stays on for 30 seconds, there is an error condition and the module will have to be replaced. If the module is OK the LED will flash 4 times.
This test, however, is not 100 percent accurate. During the test, the vehicle isn't operating, so the shift control module isn't receiving data and initiating shifts. If the unit passes the self-test, it's probably a good module. Go on to check for other probable causes, but don't rule out the module entirely. If your search doesn't turn up any other cause, it may be the module after all. You may have to try replacing the module even though it passed the self-test.
Check Sensors
A logical next step is to check the three sensors with the ignition on. The transmission sensors (manual or automatic) should be closed with the clutch in, or the automatic shift in neutral. The speed sensor should show 225-275 ohms with the vehicle stopped. Check at the module connection.
Check both the motor position sensors and the wiring harness at B4, B5, B6 and B7 and the input from B8 (see Figure 21). Make sure the harness is OK first, then check the contacts against the chart in Figure 23. Each valid combination of open and closed switches indicates a different position of the motor. For example, at the 4H position, B7 is closed, B6 is closed, B5 is open and B4 is open. Besides the three main positions (2H, 4H and 4L), intermediate positions are also shown - three between 2H and 4H and three bewteen 4H and 4L (see Figure 20 and the chart in Figure 23). Combinations other than those shown in Figure 23 indicate a defective motor sensor assembly.
Check Transfer Case Motor
To check if the transfer case motor is actually functioning (because it may be hard to hear it in a noisy shop) attach a voltmeter to A4 and A5. Have someone activate a shift and look for a brief (one second) increase in voltage and listen for the relay to click on, then off.
If there is power present, then the control module is trying to run the motor. At this point, unbolt the motor and have someone activate a shift again. If the motor doesn't actually turn, it is malfunctioning and must be replaced.
If there is no power to the motor, check both the power circuits again and the sensors. If there is incorrect sensor data, the module won't power the motor.
Check Shift Switches
If the problem isn't in the sensors or the motor, you should next check the control panel switches. Make this check with the ignition on. Disconnect the "B" and "C" connections to the sensors, so that their data won't confuse the diagnosis. Now check power at the C1 connection at the module. There should be 5 volts coming from the shift control module to the 4H and 4L switches. Check C1, C2, and C3 for short to ground.
You can check the switches themselves by disconnecting C1 and checking continuity across C1 to C2 and C1 to C3. If current passes when the switch buttons are pushed, the switches are OK.
Finally, check for a short between C2 and C3 by bridging between them and activating the 4H and 4L buttons. There are situations where wiring harnesses get crushed in such a way that two wires are crushed together and short, even though there is no short to ground.
Check Lamps
To check the lamps, turn the ignition on and ground C4 and C5. The lamps should light.
edited by Seabronc to remove inappropriate comment 11/5/2009
Gentlemen,
Since not both of you have your PM function enabled I'll handle this here. The member who made the original post did NOT come here to listen to you two bicker. This is totally against the forum rules. Please immediately remove or modify your inappropriate posts. Continuation of such behavior will get you suspended.
Just respond to the originators question on a best can do basis. DO NOT make any references to a response made by another responder. Just add your .02 and leave it that way.
ccems, I apologize for the forum. I expect that we can do better in the future :blush:
Motormouth2025
