88 Bronco 302 Lift/performance question, appreciate all input!
HallNBallz
Greenup, KY
Got an 88 bronco 302, 32x11.50x16, looks good!! I'd like to go bigger tho!! at least to a 34" or 35" tire.. now im not for sure if my truck has a lift on it or not now, but i do know there are dual shocks (4 total on front suspension) on the front of the truck, with single coil springs inbetween... I was looking at rough country lifts, they seem to have killer deals on 6" suspension lifts, around $450 i think... Manly what i want to know, should i change the gear ratio? if so what would be good? and how to do it?..... Also should i just use the aftermarket rims on the truck (which are 16" and dont know the width tho they dont stick out, about flush with fender well edge, stock i think is 15" x 7" and are a bit tucked inside the fender well)... I really appreciate any input, and the guys that have helped me with the speedometer problems
Krafty
Ontario Canada
what ever you do, do it your self, cause you will learn more. if you want to learn your gonna have to do it sometime.
digs
