87 locking hub
KG4OFQ
1897 Ford Bronco 4x4, EFI.
What gives with this crappy locking hub, I have one that needs to be replaced and cannot find anywhere accept ford dealerships that have anything to go there. No aftermarket parts avail is there.
And the price, OMG just for one the dealership wants $200 after discount.
Is there any Aftemarket Locking hubs that I could get to replace this waste of metal thats on there now. Im sure you guys know which one Im talking about. Its the only year I have see that had this type of locking hub and I dont want it if I can help it.
Is there anything I can do short of doing an axle swap.
magnumpi
I've got a stock set of the hubs your looking for. I'll sell 'em both for $80 shipped to ya. Just email me if your interested.
I *think* you can buy a a kit from warn that will convert your axle to recieve the "standard" hubs then buy new hubs. the conversion kit is about 55 at advance auto. the hubs are around 70.
email is [email protected]
Wow :unsure: , that must be a real classic Bronco, one of the early model huh? :D /emoticons/[email protected] 2x" width="20" height="20" /> Henry's cars sure did a lot of off roading, since ther wern't many then. :eek:)
Sorry, couldn't help myself :rolleyes:
Jeff's Bronco Graveyard 80 and up catalog page 29.
magnumpi
seabronc, i don't think you understand. In '87 the engineers came up with a "brilliant" idea of a hub that was only held on by the wheel. it was only used for one year. making it rather rare. all the others use regular style bolt in lockout hubs.
heres the ones we're talkin about:
http://broncograveyard.com/products/cat/20/159/32122
even more expensive than buying it from ford
You are right, I was confused, I was thinking of converting auto's to manuals. :blush:
Well, you could totally convert to the 80 - 96 (except 87 ) hub arrangement. It would cost a lot more but that is the last time you would have to deal with the 87 style. There is another thread in this forum on that not more than a week old.
So if that is not an option for you, it looks like Ford is the place to go.
B-man
16476[/snapback]
Hit up a Pick N' Pull Junkyard and grab the WHOLE front end of a 89 to 91 I think. I have an early 88 and the same damn problem.. Ford used these useless hubs for a whole WHOPPING year.. Brilliant idea.. I bet you could get a front end (rotors, hubs, etc) alot cheaper then buying "new" hubs for it.. That is gonna be what I am doing..then upgrade to the better aftermarket warn hubs.
Pony-boy
That's not a dent, It's a gift from the t
Roy, WA
It may be in your best interest to swap knuckles with a later model Bronco.
cowboydan
my buddy has a 3/4 superduty, he went out to his truck one morning and found both his hubs stolen! i thought it was a good idea for 87. .....didn't matter though, both were damaged from our last time out anyway...lol
K
KG4OFQ
This is the part listed at the Bronco Graveyard which is hte part I neDana 44 Hub, disc 1976 - 77ed.
magnumpi is this like what you have. If so then I would be interested in them if they work.
As for the Conversion would this part work Dana 44 Hub, disc 1976 - 77
I looks like the only thing is whether the spline is the same or would that come in to play, havnt looked at area in a while.
dirt
alaska
ford used those pieces of garbage in 87-88.5 model bronco and f-150s. you'll need everything from teh knuckles out to swap it over to normal hubs.
magnumpi
16855[/snapback]
Yes, thats exactly what i have. They work. The dial is sun fadded, thats it. If you are internested in them drop me an [email protected]
Thanks
Josh
magnumpi
KG4OFQ, that part you linked to isn't the right thing for the conversion. Thats for a solid d44 frontend. You just want the conversion kit that warn makes. You can find it on advanced auto's website.
K
KG4OFQ
KG4PDB what part of NC you in, and are you able to call into the PALS net that links the top end of SC. go to www.palsnet.com I think it is and check out the linked repeaters and might can give ya a shout if I ever get a day off.
I will drop you an email about those Magnum if they are the same as the ones on my 87 Bronc then I will be glad to see about gettign them.
wtfdissux
Buffalo, NY
the hubs in question are from late 87 to early 88 and yes they **** the ones at the dealer are get this the wrong ones they claim that they fit 77 thru 91 when i called for my 88 almost as if ford is trying to forget the whole idea
i went to a local scrap yard and found a set off a 90 both complete knuckle outs for 90 bucks figure for the most part the only thing that goes bad is the hub then ok fine another 60 at the most and your gold again
my question is first when i look at the blow up of mine and the "normal" type the hub spindle and rotor look the same so what gives also the kit from bronco graveyard is for pretty much every thing (even ball joints) what if mine are new already? is there a way to buy just what i need? b-(
tripleh87
Benton Harbor, MI.
i didn't need a conversion kit when i swapped out my auto hubs for manual hubs. i had auto locking hubs on my 87 bronco and swapped them out for a set of warn premium locking hubs. i got my manual locking hubs from advance auto parts for $85. i have a link around here somewhere or i can get it again if anyone needs it. let me know.
B-man
17826[/snapback]
You probably have a late 86/VERY early 87 or something. Or , maybe Ford didn't mess with the auto locking hubs on the 87, and they are the same. I saw an 87 with locking hubs and well., nevermind, The auto hubs would have to be different then the shit 87-88.5 hubs, Sorry , resolved it myself. >
truckdriva
if it aint broke, fix it anyway!
Franklin Tennessee
Definitely check WARN for new manual lockouts.
16516[/snapback]
dont bother checking warn for replacement hubs, they dont exist. i have an 87 also, found some used ones at my local junkyard, bought everyone i could find at $35.00 a-piece, i just keep them in the truck
Wihill
