Yo bronco ******
Check for vacuum leaks, see my diagnosis @
http://broncozone.com/topic/23994-90-58l-getting-continuous-code-33-and-running-code-44/?p=125535
Post #20
Have plug wires been replaced just before this happened?
Air filter, is it relatively clean?
Air inlet atop radiator support to filter box and to throttle body; look for obstruction; damaged tubing
Fuel quality, did you buy gas before this happened?
Oxidized fuel often turns darker over time and may even smell sour. You can check gasoline by pouring some into a clear glass container and comparing it side-by-side with known fresh gasoline. If your old sample looks noticeably darker than the fresh gas, you have strong evidence the gas has gone bad.
Top Tier Gasoline, see
http://www.toptiergas.com/why/
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Some basics;
If you can, run it around to heat the engine up and shift thru all gears including Reverse.
Do KOEO test First
KOEO
KOER
