87 bronco 2 transmission ups and downs
xxmillionknivesxx
Ok, just picked it up from the shop, had a new fuel system put in, things are going great get about 20 miles and wham not only does it shift veryHARD (is an auto) but then doesn't move at all, so I get out and check the transmission fluid sure enough too low to build pressure (had the same problem with my mustang however it took a while to find a leak in the line for that car) anyways, go and get a bottle to fill it up get it home. Thats when I notice it leaking out not just in drips but in puddles. I purchased a bottle of transmission additive to stop leaks and help the shifting, so far the leak is down to drips however it doesn't quite stop not untill it cools down, shifting is improved however.
My question is this, should I get another bottle of trans-fluid, additive and change the filter and gasket to fix these problems?
digs
