when it dies leave the ignnition on and check to see if you have power at the coil,module,fuel pump,pump relay,check evrything for voltage after it dies.
there should be a sharder valve on the fuel system somewhere it looks like a tire valve check for pressure there when it cuts off.
are all your grounds hooked up?all of them even the hard to get to ones?
break out the multimeter and start checking it's free,and everybody likes free.
i'm no super mechanic but sometimes a little testing will save you alot of time and MONEY.
if you have to go buy a book from idiotzone,it'll tell you how to test everything.find out and let us all know
