86 bronco starts and shuts off
M1llionb
Houston, TX
Hello everyone,
I am new here, and new to my 86 bronco. I am not an expert. I have little knowledge in fixing vehicles. With that being said, this is the issue at hand. My bronco starts and then turns off. It stays on for 3-5 seconds. These are the parts I've replaced, fuel pump inside the tank and the one on the chassis. The fuel pump relay And fuel pressure regulator. I was reading I should try changing the ICM but I can not locate. Please help. Thank you
Jgrden
Crosby, Texas
This sounds like a job for the Supreme Commander. ​ am wondering if it is carbonated or fuel injected.  My '85 is fuel injected.
Well, if it is an 86 302L engine, it is fuel injected.  One of the first thins you need to determine is if it is ignition or fuel before you change any parts.  Throwing parts at it only costs you a bunch more that it should.  After it quits, check to see if it has spark, a very easy task.  After it stops running, pull one of the plug wires and see if it will arc to the engine block while someone else tries to start it.  You should get a clean blue spark that will jump about a 1/4 inch, not a weak orange spark that only jumps when the end of the wire is almost touching the block.
Report back with the result.
M1llionb
M1llionb
Houston, TX
At first I knew it was gas because the fuel pump relay was dead. Now the truck ignites but it dies. I put a ***** driver at the end of a cable and put the ***** driver to a bolt. And it's sparking but I did not pay attention to the color.
M1llionb
M1llionb
Houston, TX
The fuel pump seems not to shut off. I hear it on even after I remove the key from the ignition.
M1llionb
M1llionb
Houston, TX
Seabronc, Thank you for your help! I apologize for the late response but I'm still new to the website. My truck now stays on and turns off without a problem. It was the fuel pump relay!
Lana Kane
