Any manual transmission from an RBV, (Ranger based vehicle, Ranger, Bronco II, Explorer) up to 1995 and possibly newer.
According to the Chilton's manual, your 84 does have a hydraulic clutch. On the engine side of the firewall, drivers side, you should see a light colored container with a ***** on lid and a hose out the bottom. Follow the hose down the firewall, it should connect to a part that is attached to the firewall on the outside. Now go inside and look under the dash at upper part of the clutch pedal arm, it has a rod attached to it, that is the rod that pushes the piston in the hydraulic cylinder you saw the bottom of in the engine compartment. While you are looking under the dash you may as well figure out how you are going to remove the clutch pedal assembly, you are going to need it, hint, the metal panel under the steering column is removable, some were screwed on, others had plastic twist screws.
Do you have a Chilton's or Haynes manual? If you do not, you should get one, you are going to need it before you are done with is swap. A manual will give you the specifics that will be very hard to explain here.
Ray
