broncovilla
- Joined
- Sep 11, 2009
- Messages
- 2
- Reaction score
- 0
I have an 84 full-size bronco with a 302. It starts and idles strong. When I give it gas it will bog-out, loss power and at times backfire. At first, I could shake the plug wires and the computer wires around a bit and it would work fine. Now, the loss of power is constant and immediate. So, I changed the plugs, plug wires and distributor cap. No change. Then, I cleaned the computer wire connectors. Still no change. My next step is to make an extensive check of vacuum lines but at this moment there appears to be no leak. I will also try a substitute computer module to see if mine is bad. If it is not the computer module or the vacuum lines, what would be my next troubleshooting step? Test for spark? Test for fire? Timing? Compression? Or could there be a carb problem? Fuel filter/pump problem?
